The thing to remember about the ICP/PW relationship is that the pulsewidth is already based partly off of ICP. So technically, if you raised the ICP then the pulsewidth should drop automatically. You shouldn't have to go in and make any further changes. Unless I change the injectors, the main pulsewidth table doesn't get touched. It's all handled elsewhere. Cody... Cow farts. That's funny right there, I don't care who ya are!
Back after many years. 2003 F250 CC LB 4x4 7.3PSD Minotaur user. |
It'll run, but the biggest thing you'll notice is that the truck will seem a little slugish on acceleration. We've been there and done that and that's why we don't offer Fuel Sipper anymore. To many complaints that it just didn't pull well off the line at light to moderate throttle. Of course, heavy throttle worked nicely but then what's the point of the program?
You'll find something that's going to work for you. Things that have always helped me with economy: Shifting (lower the shift points) ICP (up 5% to 15%) SOI (up 2 to 6 degrees) Hope this helps.
I am looking for a really economical freeway program 1100 miles one way, shifting doesn't really become an issue. Ill bump the SOI and ICP up a little and see what happens ![]() Actually 90% of the time I am very light on the throttle, but if I need it to, putting my foot into it I want it to move.. so that actually would work well for me....
DJ,
Make sure you are not significantly modifying BOTH the SOI Main and SOI Offset tables. They compound each other and can easily result in SOI values well over 45º. For reference, stock is about 24º at full throttle at around 3000 RPM. Dave, Since the SOI is handled in degrees on the SOI Main table, this is easier to translate. The SOI Offset (Delay) is much more vague, but is also more useful in the respect that you can control the temperature at which timing is added. This prevents one from running too much timing when the engine is cold and possibly causing damage. You could also use the SOI Adder vs. ECT, but this lacks a bit of resolution as it is only 7x7 to start with and 3 cells are wasted below 800 RPM.
I was doing some figuring on milliseconds vs degrees and rpm... is this right @600rpm= 10revs/second = 1rev/ 0.100 seconds or 100 milliseconds this 100/360 degrees = 3.6 degrees of rotation per millisecond at 600rpm or 7.2 degrees of rotation at 1200rpm ...10.8deg/millisecond at 1800 rpm and so on... so for example at 1200 rpm an injector pulse width of 2ms would inject diesel through 21.6 degrees of rotation ??????? definitely doin' too much thinkin' 2nite... ![]() Is there a constant for the burn rate of diesel... or I guess it would be on a slope variable to temp hence the reason for the offset for cold temps???
See if this calculator helps...
Also, I think you boo-boo'd your calculation. I think you meant 21.6º of rotation at 1800 RPM and 2 ms. In any event, the rest of your math is correct.
How about for altitude? And how many feet above sea level counts as high altitude? |
