Old Mon, December 28th, 2009, 02:41 PM
One more......
Besides the LBF map, what affect does boost have on fueling?
Old Tue, February 23rd, 2010, 11:10 PM
Yet another for you..........
What the heck does the Indicated Torque map do?
More shifting stuff?
How about the Exhaust Backpressure Torque Loss map?
Same thing?
Old Wed, February 24th, 2010, 08:28 PM
I think that the Indicated Torque has to do with the data on the scan tool. I think it is calculated using the torque table and the torque loss maps.
How about the Exhaust Backpressure Torque Loss map? I am not completely sure, but I think that calculations are made from this map to give scan tool data and it MAY also have an effect on the torque table map to further enhance the PCM's shift pressures.
Same thing?
Quote me on NOTHING!!
Old Sun, March 7th, 2010, 02:01 PM
What causes the truck to jerk at very light throttle or when easing off the pedal, especially with the TC locked?.......MFD?
Can SOI affect how touchy the pedal is?
Old Mon, March 8th, 2010, 01:31 AM
Indicated Torque Map and Exhaust Backpressure Torque Loss are used to estimate how much NET torque the engine is generating. This value is then used by the transmission portion of the strategy to generate the base line and shifting pressures. The Pressure Slope is basically how many PSI per Ft./Lb. of torque to set the line pressure at. The the Pressure Offset is then added to this value.
For example:
Your Pressure Slope is 0.1811
Your Pressure Offset is -6
The Calculated Torque Output is 420 Ft./Lbs.
420 Ft./Lbs. x 0.1811 PSI = 76 PSI
76 PSI + (-6) PSI = 70 PSI
The PCM will set the line pressure to 70 PSI.
This also goes for the shift slopes and offsets.
Jerking at light throttle can often be caused by MFD or ICP. MFD is more appropriate for adjustment since it directly relates to throttle position.
Hope this helps.
