Old Thu, January 7th, 2010, 10:22 AM
Originally Posted by lordfeyr View Post
Thanks for the reply. Would the level 2 tune bring about that drone? Ive had the intake on for a couple weeks and never experienced it until right after putting the tuner in.
Interesting! It might. You could try the Level 1 (Tranny Only) tune then. Essentially, it leaves your engine at the stock A/F and spark settings but does all the good stuff to your transmission that makes driving so much better. If the noise goes away, I would say the engine adjustments in the Level 2 tune, coupled with your intake are the cause. And, I'd leave it in the Level 1 tune till you get your custom tune(s).
This information would be very helpful to Bill when he writes your custom tune, so that the noise is eliminated.
Old Thu, January 7th, 2010, 11:29 AM
If the drone is annoying you?
The thing I'd suggest is put the stock intake back on and wait to reinstall the roush CAI until your custom tunes are done.
Then you could safely try all the tunes.
Just a thought.
Old Thu, January 7th, 2010, 12:34 PM
lordfeyr lordfeyr is offline
lordfeyr is on a distinguished road
Im at work right now so I will try level 1 when I get off. This morning the noise was noiceable less compared to last night so maybe operating temps or outside temp
The noise is not really bothering me its just new so I wasn sure if its normal since the intake was on before the tunes with no drone. That and I felt it more than just heard it.
I am thinking its the intake now as it only happens coming off idle with lower rpms and slight throttle.
Old Thu, January 7th, 2010, 05:04 PM
The other thing I'll add is when you first program the pcm, the gryphon needs to build files and the pcm starts to learn new strategies. So some noise at first may be reduced over time but it also may slightly increase. The CAI noise is kind of a crap shoot with the canned tunes.
Old Thu, January 7th, 2010, 08:19 PM
bambo2888's Avatar
bambo2888 bambo2888 is offline
bambo2888 is on a distinguished road
i actually noticed that today. i did about three different tunes today, with test drives in between. after loading each tune, there was a drone, but went away a few minutes of driving. this happened EACH time i loaded a tune, with only about 2 min between drives.
04 Lariat 5.4 4x4
Gryphon Programmer custom tuned by Bill at PHP ~ 325/60/18 Terra Grapplers ~ K&N Cold Air ~ 2.5 HBS Level ~ Skyjacker Shocks ~ SI/DO Flowmaster 40 w/ deleted rear cats ~ 8000k HID headlights and foglights ~ Blacked out tails ~ Hardwired STI Driver ~ Rockford Fosgate Amp, 10" Sub, w/ Infinity References
BLACKED OUT TAILS FOR SALE!!
