Old Thu, January 7th, 2010, 09:48 PM
My truck has always smoked for the first 5-10 minutes after a sub 15 degree start. It was -31 here today and it started right up.....but smoked pretty good until I left the house 20 minutes later. I've also got 130K on my truck and it DOES need injectors.
The glow plugs are on for 120 seconds when the engine is that cold. Once they turn off, the engine is relying on compression heat to burn the fuel efficiently.
The smoke, if it smells like raw diesel fuel, IS unburned fuel. The stock setting on the chip DOES NOT use the original PCM for anything.
I replaced the glow plugs in my friend's truck about a month ago....even though they tested fine by every measure of the word. The difference in cold starting is night and day.
Old Thu, January 7th, 2010, 10:00 PM
zeuss zeuss is offline
zeuss is on a distinguished road
Does this problem I am having sound like a injector issue. It seems to me if I am still getting 15 to 17 this time of year they can't be to bad. I will also say that I am on my 3rd relay in 12,000 miles. So I wondered if even though they tested good there could be a problem. ( More resistance equals more aamps) I didn't ask how they tested them. I have thought about changing them anyway.
2002 F250 CC A/T
33 BF Goodrich
Autometer Trans, Pyro & Boost on the pillar
Zoodad
PHP stock, 40,60,80,100, and whisper
Old Thu, January 7th, 2010, 10:02 PM
I will also see what happens in mornig without chip in. This is the first winter I had the chip in and also the first winter I had this problem.
2002 F250 CC A/T
33 BF Goodrich
Zoodad
Old Thu, January 7th, 2010, 10:48 PM
Like Cody said, the glow plugs are off after 2min or less and should not cause excessive smoke after a few minutes............ but there is definitely an issue there if you keep changing relays.
My truck and many other trucks I have been around have always smoked for quite a while when cold.
Does anyone know how long the Air Intake heater stays on for?
Might be worth looking into.
Old Thu, January 7th, 2010, 11:08 PM
I had resistance tonite on the aih. I don't think the aih comes on while the gpr is actuated though.
2002 F250 CC A/T
33 BF Goodrich
Zoodad
Old Thu, January 7th, 2010, 11:17 PM
No.... but it's intent was to reduce cold engine emissions...
Old Thu, January 7th, 2010, 11:46 PM
I'll have to check it. I'm interested to see what happens in morning withuot the chip in.
2002 F250 CC A/T
33 BF Goodrich
Zoodad
Old Fri, January 8th, 2010, 05:55 PM
Well it smoked like heck til warm again. Pulling chip did nothing different, just took it out of equation. Next questonis could the glow plugs be bad even though they tested good for them. Not sure how they tested them.
2002 F250 CC A/T
33 BF Goodrich
Zoodad
