Old Fri, January 8th, 2010, 02:49 PM
Ok from what I understand of what Bill has told us in the past is that 87=89.
The other one is 91=93.
This how he sets his strategies when he writes custom tunes.
That's how the canned tow tune and canned performance tune are set up also.
So increasing a couple of octane points isn't going to help or hurt anything.
Old Fri, January 8th, 2010, 03:12 PM
Correct, as Lars just said. But, you MAY be able to increase your spark timing by about 1 degree if you move 2 octane points up the scale. This SHOULD give you slightly better performance (if it doesn't induce pinging). If it DOES start to ping though, the PCM will reduce your timing even more than you advanced it, and you'll lose performance.
Old Fri, January 8th, 2010, 04:04 PM
GunMetal06 GunMetal06 is offline
GunMetal06 is on a distinguished road
Ok, thats good to know. I don't really want to mess with the timing or doing my own tweaking. I'll probably end up with a piston through the block if I do. But at least I know I have the option of 87 and 89 without too much to worry about.
Thanks for the info!
