2004 to 2008 F-150 and Mark-LT 4.2L, 4.6L and 5.4L equipped F-150s and Mark-LTs. |
![]() Quote:
Believe me, I'm not used to this clean of an engine bay myself...I just bought the truck last October. My previous truck was a lifted '78 Bronco with a 460 last I used to mud all the time. The engine bay in that truck wouldn't come clean, no matter how hard I tried. Thanks for the comments guys. |
![]() Quote:
There are three resonator chambers. The front large one has a larger hole near, but not at, the lowest point and then another, smaller hole up higher, close to the halfway point. The small rear chamber has a hole at the lowest point. The smaller front chamber has no holes at all. So, the ones with holes could have them for draining water too, but why are they not at the lowest point in the big chamber? As I said, I'm lukewarm to the holes being drain holes, but why have some of them "uphill"? On a related note, AgentOrange, I looked through your album at your intake mod. Nice work! However, I'm a little concerned that the intake sitting right behind the tow hook is positioned to really take a big drink of water in the event of driving through a deep puddle or maybe even just heavy rain. I know the tube runs uphill quite a distance from that point, but when the engine is at high rpm, isn't it possible that there could be enough suction to pull water up into the filter box? I like the ram effect idea, but I think if I were going to do this mod, I'd run the secondary duct up high, perhaps just under the headlight. You lose the ram effect here, but the opening would be out of the hot engine compartment. I like the flexible metal duct into the fender well. Sure looks easier than shaping a rigid ABS tube. - Jack |
Jack,
My thoughts exactly if I only had the scoop at the bottom, but I don't think water intake would be a problem because of the second air inlet into the fenderwell. Think of drinking through a straw...If there is a hole in the straw above your favorite beverage, all you suck in is air...path of least resistance. |
Yep, you're probably right! I suspect there's no way you could create a big enough vacuum to pull water up that distance.
- Jack |
Looks good! Maybe put some type of soft material along the edge of the hole. I wonder if the intake noise resonates through the truck due to the pipe touching the fender??
2000 Black Excursion, Two 400hp 7.3 blocks with windows ![]() |
Jim, I'm certain Bill did not use the AgentOrange design. That's a pretty unique idea I think!
I'm fairly certain it was of the kd4crs ilk, or maybe even just an open tube minus the bellows and snorkel. - Jack |
![]() Quote:
I wish I could take full credit for the idea, but Banks beat me to it. If you notice, his design also uses the fenderwell inlet. Check it out: http://bankspower.com/products/show/32/50 lot's of info there. I doubt my mod makes the power his does, especially because I am still using the stock filter, but the principal is the same. I think the main point of this and the kd4crs mod is to allow the engine to get as much air as it may need and keep it as cool as possible...plus, I just like to tinker with things. Just my .02.
2005 F150 King Ranch SCrew 4x4 Flowmaster SIDO exhaust DIY Ram/CAI Electric Fan Leveled w/ 20" wheels 3.73 LS |
I did this mod on my 08' 4.6, it was quite different since it uses the cone style filter, the PVC pipe is about 4 or 5 inches long.
I will post a picture of it when I get a chance if wanted. |
![]() Quote:
Post it, I haven't seen the new style yet.
Not mine but with the mod the only difference is where it meets the fender all you can see is the PVC pipe coupler I will get a pic of mine up later
Tags |
dwv intake mod |
Thread Tools | |
Display Modes | |
