There is not any maintenance that you can really do to the front unit-hub bearings. However, I have packed them by using a standard grease gun and pumping grease into the ABS sensor hole. Does it do any good? Who knows. I just do it for the peace of mind.
Are you talking about the locking hubs, or wheel bearings?
Thanks for the info Cody.
907 Dave: Locking hubs. |
Well in that case, you do not want to put any grease in their. The only thing that you could grease would be the axle shaft thrust washers, they sit right behind the hub and are held in with a snap ring.
Thanks Dave.
i like to take my hubs apart clean them and them put some synthetic marine grease in them, not to much it will cuase cause the intermedate gear to hang up in the lock position.
In the past few weeks i have worked on 3 superdutys that had at least one hub stuck in the lock position, when I pulled them apart the were all dry and had a lot of dust in them. I would keep an eye on the outer axle shaft seal. If that goes to hell the little axel shaft bearing follows shortly after. you need a special tool to drive thoes seals in, i don't know what the part # is bought mine on ebay for $35 |
I have some new take offs for sale. PM me if you want em
2003 F-250 7.3L Superduty Ranchhand Bumpers front and back ~ 6637 Intake ~ Zoodad ~ CCV ~ 5" Exhaust w/ 6" SS tip ~ Train Horns ~ Viair 450C ~ 5 Gallon Air Tank ~ Sound System ~ PHP Phoenix 6 position ~ 4 Dipricol Gauges on the Pillar ~ 05 Conversion ~ 08 Taillights **Soon To Come** 08 Tailgate ~ Adrenaline HPOP ~ More Gauges ~ Built Engine |
