The piece is just held in by a couple of molded in clips. Just grab hold of the change piece and give it a good tug. May take a time or two. Much like the center console surround-trim that is around the radio/climate control. The first time you'd swear you're going to break something. After that it becomes easier each time. If you prefer, you can remove the surround-trim and reach inside around the back of the change holder and push it out from the backside. Again, either way it's just held in with molded plastic clips.
Before you try and beat the odds... make sure you can survive the odds beating you! |
Well now I wish I had paid more attention because I had that area opened up because I was installing a remote starter. I'll see if I can find something to put in its place then because I dont really like it. Maybe I'll make a GPS holder to put in there.
Later: Wow, that was actually pretty easy I just never tugged enough to pull it out. But now I'm really curious as to why a coin holder needs a wiring harness? - - - I'm thinking about getting my wire tester and seeing if they are actually hot.
The wiring harness is for the 4WD control on vehicles equipped with 4WD.
Correct but also incorrect. I have a 4x4 but I have a manual 4x4 with 4x4 shifter on the floor. I have the coin holder as shown in the picture so this mod isn't just for 2WD only.
Custom Gryphon Splash Screens
█ F150 05 5.4 XLT, Nitto 295/70/17, Dual Flowmaster, Gryphon w/ Custom Tunes █ █ K&N CAI, HBS 2 1/2 Level Kit, Blackout Heads w/ 8K HID's, Tinted Tails & 3rd Light w/ LED's █ |
