Old Thu, January 29th, 2009, 10:17 AM
AgentOrange's Avatar
AgentOrange AgentOrange is offline
AgentOrange is on a distinguished road
I wonder if the intake noise resonates through the truck due to the pipe touching the fender??
No noise so far...
I really don't like the way the 90 degree elbow is fastened to the frame either, via zip tie, but it'll have to do until I can firgue something else out. I don't want to drill any holes in the frame and I don't want to lose the tow hook either.
Old Thu, January 29th, 2009, 12:41 PM
kokopellimotorsports's Avatar
addicted
Excellent work people. I am working on a tech section on my website and would like your permission to post this up Jack, and anyone else that would be willing to have it posted. Thanks. I just removed the snorkel and left it open in the engine compartment.
2001 Dodge Cummins
Tuning is addicting. Lol.
Old Thu, January 29th, 2009, 01:12 PM
Feel free to post anything I've talked about kokopelli - It's NOT copyrighted and it wasn't even my idea. Just my implementation. I've also added an album in my "Albums" on this forum that shows this mod and I've included dimensions in the captions. You may want to look at that too.
I wonder if removing the snorkel and leaving the intake open in the engine compartment is a good idea though? Wouldn't that tend to draw "warm" (less dense) air into the engine, which sort of defeats the whole purpose of an improved intake?
Old Thu, January 29th, 2009, 01:20 PM
addicted
Thanks for the info. I will check out your Album.
As far as the hot air, this probably could be an issue, but most cold air intakes set their filter right in the compartment. Though I do agree with the logic of colder denser air. With your write up I will probably do much the same as you.
2001 Dodge Cummins
Old Thu, January 29th, 2009, 01:30 PM
Some of the pictures I've seen show the filter in a kind of "box" that looks like it's there to isolate the intake area somewhat from the engine heat. It's also possible that when moving, the whole thing is a moot point anyway due to the airflow through the engine compartment (as long as you keep the intake away from the flow through the radiator).
Old Thu, January 29th, 2009, 01:44 PM
Again, when I get questions about leaving the end of the tube open, I always end up going back to the 60's & 70's cars that had air cleaners with the snorkel that barely made it past the valve covers.
From a performance aspect, cooler air is always more desirable than warmer air. Although, like Jack, I wonder just how much warmer the air really is getting in the intake tube when blasting along at 70 MPH. This would be an easy thing to validate since the programmers have ACT in the PIDS. If it was less than 10º difference, I'd wonder just how necessary it really is to complete the tube connection to the fender.
As for CAIs, there's no question they're drawing some amount of warm air from under the hood. Again, a quick check of the ACT before and after installing will give you the final word.
Old Thu, January 29th, 2009, 02:28 PM
kd4crs's Avatar
kd4crs kd4crs is offline
Not a Whopper
kd4crs is on a distinguished road
Hey Bill, did you get the write-up I emailed you? I did not see a response. Sometimes I wonder if my Hotmail account emails I send don't get eaten by the spam filters.
Old Sat, March 28th, 2009, 10:10 PM
SubiGT's Avatar
SubiGT SubiGT is offline
Location: 2nd star to the right, straight on 'til morning(Ohio)
SubiGT is on a distinguished road
I have the OEM airtube open. I also just got my Gryphon. The ACT(PID) and OAT in the factory gauge cluster were 8deg split all day today. 54(OAT) was 62(ACT). The ACT would climb when sitting, but would quickly drop to the 8deg difference when moving.
I am going to get a 12" section of black ABS, but I really don't expect to see the ACT ever reach the OAT.
current off road toy
Tags
dwv intake mod
