Old Wed, March 3rd, 2010, 04:32 PM
ROB281 ROB281 is offline
ROB281 is on a distinguished road
noticed that mine is off as well
my gps says the distance between my office & apartment is 24.9 miles
odometer says 28
my speedo is also reading slower than the gps as well
Old Wed, March 3rd, 2010, 06:26 PM
odometer says 28
So then to correct it all you have to do is multiply your current tire size by 1.1245 (28/24.9)
Also, write down the new tire size on a piece of paper. That way, if you have to adjust the tire size more you can multiply the odometer/gps fraction by the number you wrote down.
Its also a good policy to write every change you make with the gryphon down onto a piece of paper and save that paper for future reference. I keep my paper in the pod behind the gryphon after I fold it so that it wont be able to slide out of any cracks...I resort to the good old fashion paper ball fold.
Old Thu, March 4th, 2010, 11:47 AM
gilsnuxs gilsnuxs is offline
gilsnuxs is on a distinguished road
OK, Ive tried the formula using the odometer and my speedo is still off by the same amount. GPS reads 67, CTS Unit reads 70, and Truck speedo reads 73. Stumped. If it helps, I have Nitto 325/60/18 so I used 2660. Truck odometer was 10.7, GPS was 10.3. I got 1.0388 x 2660=2763 2763-3% for squish=2680. THats what I used.
Old Thu, March 4th, 2010, 12:10 PM
shotgun's Avatar
shotgun shotgun is offline
Gryphon CTS
Unloaded circumference is 2662mm. Allowing a 3% squish factor = 2662 x .97 = 2582mm
Double check:
10.3/10.7 = .96
2582/2680 = .96
Also make sure that you are properly saving the custom settings.
http://forum.gopowerhungry.com/faqs-...ions-menu.html
Old Thu, March 4th, 2010, 12:12 PM
Looks to me like you've INCREASED your TS for "squish", which would make your CTS read "too fast", A 3% squish on your tires reduces the circumference to 2581. That may be too small, looking at your numbers, but the correct TS should be somewhere between 2660 and 2581.
Edit: You're too fast for me Shotgun! And you were absolutely right.
Old Thu, March 4th, 2010, 12:14 PM
Ok, dont worry about squish when you use this formula. The tires size in the programmer should already compensate for that.
I'm not at my computer right now but I think when I put in my tire size and play with the amount of squish it comes out to 4.5 or something like that for 235/70-17 tires on an 8.5 inch rim. Try using the 2763. This method isn't always a one shot deal sometimes. Things like GPS errors and incorrect tire size values can throw it off.
Haha and I didn't see you other guys post.
