And why only when coming down off of a fast idle?
did I miss something? where do I get a 200HP DD
Back after many years. 2003 F250 CC LB 4x4 7.3PSD Minotaur user. |
Once you get injectors and compounds like Dave has.......
Heh, would have to change those lil' thingies in his Avatar pic first... Hoping to do an Adrenaline this summer, Injectors down the road but prob just single shots
Whoa......new mod in town.
Have fun parting it up hardcore with the other mods.
Ok......
The relationship between the injection pressure regulator and the actual/desired injection control pressure goes a lil' sumpin' like 'dis. 1. The PCM bases an initial injection pressure regulator duty cycle using the IPR map to attain a desired injection control pressure. 2. The PCM looks at the actual injection control pressure data from the ICP sensor. 3. The PCM makes fine adjustments in the IPR duty cycle to get the desired injection control pressure reading from the ICP sensor. Every varying load/RPM will start with an initial duty cycle commanded by the PCM and constantly tailored adjustments by looking at ICP sensor output. This entire system is called a "feedback loop". It's very similar in operation to how the oxygen sensors relay to the PCM about how accurate the air/fuel correction is. When the base IPR duty cycle is off, then the initial duty cycle for a desired injection pressure is off and if it's off too far in a certain operating range, then the PCM cannot correct it and maintain a stable RPM because the actual pressure desired varies too much from the desired and the PCM basically fights itself because the map is no longer valid. I recognize that as a run-on sentence but I'll leave it that way because that's how it came out of my head. I know what I want to say but I don't think it came out right.
Came out fine.
Thanks, it makes more sense now. The duty cycle map is a bit more involved than I originally thought. How would a guy fine tune this map, besides in the low ICP range with BO is it even necessary? oops....BO= big oil.
Actually, data logging can be a great tool when fine tuning the IPR map. I was doing some testing/tuning last night for my extreme towing program (which really doesn't make much more power over stock) to get some things just right. Remember how I said about a week ago that I had something to test? Well, I was working on that.
If you see certain trends in your IPR DC% that cause you to wonder..... I'll post some datalogs and screenshots one of these days in the near future. I didn't set out to do any IPR changes, but I ended up making a few. ........and if your BO is that bad, then I think you need more help than just some fine tuning.
Tuning, PCM flashing, and burning chips for 7.3s since 2008. Repairing all aspects of 7.3L Powerstrokes for 25 years. Eight 7.3L PSDs in the driveway including a 1994 Crown Vic and 1973 F100/2002 F350. Looking for the next victim. Last edited by cleatus12r; Sun, March 14th, 2010 at 08:39 PM. |
Cant wait!
I think I need to get the emulator stuff so I can get some actual live tuning done. I think this will be a great learning experience for me. |
