what should a 17* HPOP max out at (pressure), I am also thinking I may need more then 90cc of fuel.
Jay 413-222-8286 I got hay for sale '97 F350 CC, DRW, pickup, 7.3, E4OD, 2wd, 4.10, 405K '00 F550 reg cab, 11' flatbed, 4x4, 7.3, 6637, 4R100 (soon to be a ZF6), 290k '97 GMC 5500, getting a transplant, 3.36, sleeper, 350k Abolish the Federal Reserve, They are the #1 problem. www.prisonplanet.com |
All depends on tuning, and injector type/ size.
But with stock programming all you are going to see is 2800psi. |
thats what it's doing.
If I was to crank it up with tuning, high high can it safely go? Will bumping the HPOP pressure do much for power or economy? I want to do all I can to squezz out all mpg i can.
Do you have a chip on order? |
I sent Bill a message last week, (he has not responded yet, but thats OK I don't have the cash rite now) about getting an FU package and 3 chips, I want to chip a '99F350, '99 F450, and '00 F550 all with auto. I am told they are the same definition file.
Are the FU tunes, PCM specific or Definition File specific? Can I run one FU package (with additinal) chips on these 3 trucks (same definition file)?
i was thinking it would be nice to run able to run the HPOP at max psi from 1800rpm and up
, at like 75% throttle so it wouldn't down shift. The trucks with 3.73 cruise nice at 1800ish R's down the highway. wouldn't the mpg go up with 3000-3200 HPOP psi at 1800-2000rpm cruising rpms? I had a 10k ohm mod on a '95 PS that gave me like 1-2 mpg gain. will the rough idle (due to the single shots) hurt anything?
yeah I need to get a chip, but I just spent a bunch of cash on trailer brakes and tires. Plus every spirng I buy a lot of fertlizer.
I just put together a big construction hay deal, 7000+ bales so that will help.
