Old Tue, April 20th, 2010, 01:58 PM
could have a sticky valve or leak in the valve body
I sent you a PM
www.prisonplanet.com
Old Wed, April 21st, 2010, 03:31 AM
The transmission will default to 2nd gear any time it feels there is a problem with the low/reverse clutch assembly. Unfortunately, there are several things that could cause this and I'd be very hard pressed to offer a solution or even begin to tell you where to look.
My best advice... Call Brian's Truck Shop (870) 422-FORD (3673) and see if they might be able to offer some possible pointers. Because this issue could be either mechanical or electrical, you may have some hunting to do.
I wish you the best of luck and hope it's something simple and easy.
Old Wed, April 21st, 2010, 09:59 AM
Tholt34 Tholt34 is offline
Tholt34 is on a distinguished road
Thanks Bill. Been trying to call brian, He's a busy guy to catch up with which i understand. I guess there could be a line pressure issue there, but as far as mechanically how the tranny works, it works great. Shift fine and solid and doesn't slip. Pulled the pan last night and there were no material on the magnet, fluid was still good, I couldn't find any sticking valves in any of the valve bodies. I've read a couple post on rfi interference. Do you have any ideas on that? like alternator being good but causing interference?
Tim
Old Wed, April 21st, 2010, 10:54 AM
I've never seen that, but doesn't mean it can't happen. It's possible that the MLPS (shift position sensor) is flaking out on you and I'll try to locate the tests for that and get them over to you. Other than that, I just don't know.
Old Wed, April 21st, 2010, 12:30 PM
I'd really appreciate that Bill. I have been wondering how to test and what it exactly does. Thanks.
Old Sat, April 24th, 2010, 02:14 AM
I talked to brian at bts finally. He thinks that since i keep getting a 720 code and something is interferring with the signal from that sensor. He recommend alternator so i test drove it with it unhooked and no problems. So i bought a new alternator and so far its been good. He was great to talk to and really helpful with information.
