Old Tue, April 20th, 2010, 09:19 PM
01crewcab 01crewcab is offline
01crewcab is on a distinguished road
Thank you both for the replies. I did not return it to stock. It's a long story. I basically have a fuel relay shutoff, that's activated with a fob when you want to start the truck. Unfortunately the Tech was not informed of that and couldn't start the truck when he was done working on it. The dealership calls me and says I need a new PCM! I asked if the Tech had pushed the fob button, well no he didn't know! Yes it is an old Edge that was basically loaded with BD tunes, so the performance rating is 80hp vs 100hp on a normal EVO. I'm thinking I should send it in and get it totally reprogrammed
Old Tue, April 20th, 2010, 10:53 PM
You may not need to send it in. But, DO call Edge Tech Support on this. I'm sure Bill could help you too, but it seems more like an "Edge" problem to me, since you don't have a Gryphon.
They can certainly unlock it, and after that, I suspect a no-cost firmware update should put you back in business.
Edge has some GOOD people in their tech support team. I've seen a number of very positive responses on them in the f150online forum (where I'm also a Moderator). Please give it a try there, and if they can't help you, we'll try to get you hooked up with Bill.
Old Wed, April 21st, 2010, 12:28 AM
If it's an old Evo (as in "Gameboy" style) then any update will unfortunately require that you send it in. If it's a dash mount, then you're in good shape and the unit can be updated/corrected remotely. Either we or Edge can help you on this so just let us know how you'd like to handle it.
Old Wed, April 21st, 2010, 02:01 PM
I believe I'll send to you. Please let me know what info you need before I send it off. Thank you,
Joe
01crewcab
