Old Wed, April 21st, 2010, 01:45 PM
AZFXFOUR AZFXFOUR is offline
AZFXFOUR is on a distinguished road
Bill,
I can triple check the MAF sensor but Im 99.9% sure its correct as I double checked it when I put it in. I did drive it to work last night (24miles round trip) with out any lean DTCs but I just drove it normally and tried not to get on it. Is there a chance that because it was the first time I drove it with the new tunes and intake that it just needed some time to adjust everything? I will drive it to work again tonight and see if I can get it to come back again. Other than that issue and the shifting im happy with everything so far. Got 17mpg on the way home last night I know your extremely busy and I dont want to seem ungrateful but if you could adjust the shifts that would be gr8! Thanks
Old Wed, April 21st, 2010, 01:56 PM
I'll go another 1.5-2% on the MAF and change the shifting a touch. That should get you straight.
I'll hit you back when it's ready.
Old Wed, April 21st, 2010, 01:57 PM
Thanks Bill. I havent had a chance to try my tow tune think its the same deal?
Old Wed, April 21st, 2010, 02:35 PM
Quite possible. The tow tune should be less of a problem because they are already a light bit richer in the tuning. You could certainly give it a spin and see if it responds better.
Old Wed, April 21st, 2010, 03:14 PM
Ok I will check it out. Thanks again
Old Thu, April 22nd, 2010, 10:50 AM
OK so I drove to work yesterday with the perf. tune still loaded and tried to induce a lean DTC and never got one. Then before I left work last night I loaded the tow tune for the drive home. I was able to induce a lean (bank 1 and 2) DTC with the tow tune loaded. I have to say though, I was much happier with the feel and performance of the Tow tune! It was exactly what I would expect a tow tune to feel like and gave the throttle response that I was hoping to find in the Perf. tune. I could hold my foot in the throttle through the shifts and it never lagged, as opposed to the Perf tune where the power drops out after shifting. I hope this helps explain it for you Bill. I will say that It seems that the lean DTCs only show up if im doing a real hard accel. from a stop or when going very slow (less than 10mph)
Old Sun, April 25th, 2010, 02:12 PM
Just wondering what the status on this issue is?
