Old Wed, April 21st, 2010, 06:17 PM
The Rosewood kit is good, comes with good instructions with lots of pictures. Only problem with the DIY kits is there is no way to flow match the injectors once modified. You more than likely will not ever know the difference, especially with Stage 1's, but they might not be as balanced as a set you can purchase.
I would recommend having Jim (Rosewood) modify the injectors and flow match them. You could also look into a set that have already been done, then you just send yours back as cores. IMHO Swamps is the best in the business when it comes to modified injectors, great quality control.
You might also look into AC code injectors which are singles, they are usually pretty reasonably priced.
Ultimately it is up to you as there are many companies that are great injector builders.
For tuning, all the tunes must be for single shot's. It will run without any programing, or programming for splits but it will run very strange.
Old Wed, April 21st, 2010, 07:00 PM
Dave,
He's looking at Stage 1 Singles, which is the AC code injector.
Old Wed, April 21st, 2010, 07:01 PM
Ooops....I meant NEW AC code injectors instead of remans.
Old Wed, April 21st, 2010, 10:07 PM
That's okay Dave, I'm sure you were still trying to recover from tuning your truck last night.
Old Thu, April 22nd, 2010, 02:39 AM
MMmmm I got to call rosewood. For 500$ I have to send in my injectors to get fix which is fine BUT there not single shots . I dont have a 1000 bucks to spend for premium injectors.
Old Sat, May 1st, 2010, 05:20 AM
Ok got a question.
First
I pulled the fuel bowl and its completely apart. Is there any way i can just dip the bowl in something and pull it out to be sparkly clean? What is the fuel bowl made of? Aluminum?
Second
I bought the HPOP re seal kit. My HPOP looks new. It has a re manufacture sticker on it and appears that theres no oil leaks. Should I go ahead and pull everything apart and replace the seals??
The 2 wired mesh hydrolic line going to the middle of each head is that the oil line?
Thanks
Old Sat, May 1st, 2010, 11:52 AM
Originally Posted by epowers777 View Post
Ok got a question.
First
I pulled the fuel bowl and its completely apart. Is there any way i can just dip the bowl in something and pull it out to be sparkly clean? There is some types of solvent/ carb cleaner that will make that thing shine. I thought I seen somewhere that you can use malt vinegar as a parts cleaner/ rust remover.
Yep, aluminum.
Second
I bought the HPOP re seal kit. My HPOP looks new. It has a re manufacture sticker on it and appears that theres no oil leaks. Should I go ahead and pull everything apart and replace the seals??If there are not any visible leaks I would not worry about resealing it. Just keep parts on hand for future repairs/ upgrades.
The 2 wired mesh hydrolic line going to the middle of each head is that the oil line?That's them.
Thanks
See Blue
