Old Thu, April 22nd, 2010, 01:12 AM
I'll see if I can get the dimensions from Edge.
Old Thu, April 22nd, 2010, 11:03 PM
JWBFX4 JWBFX4 is offline
If bill doesnt have it, I could probably take my grommet boot out and put it on the cmm and generate a cad file/program for it.
Old Sat, April 24th, 2010, 12:09 AM
Punisher's Avatar
Punisher Punisher is offline
Punisher is on a distinguished road
Thanks guys... I appreciate the offer but this wasn't intended to make work for anyone. I just thought I'd ask if there was already a template file available. If there isn't, I can go old-school... not a problem. But please... don't go out of the way. I only meant that if someone could attach it to an email with a couple of clicks. Anything more than that just isn't worth their trouble.
Again... thanks. I'll post pics once I finish up.
Before you try and beat the odds... make sure you can survive the odds beating you!
Old Sat, April 24th, 2010, 10:01 AM
DarkShadowSTX's Avatar
DarkShadowSTX DarkShadowSTX is offline
DarkShadowSTX is on a distinguished road
You just gave an idea I could do with mine. I could put mine below my stereo. My original intentions for that space was going to be for putting aux switches but I should be able to fit a couple switches and my Gryphon.
Old Sun, April 25th, 2010, 05:16 PM
Nice! I like the diamond plate
I was thinking about doing the same thing once I got around to upgrading the stereo.
Old Sat, May 1st, 2010, 04:11 PM
Punisher's Avatar
Here's some pics of the finished project.
I used some 1/8" plastic sheets found on ebay. They're already scribed at 1/4" increments on the back side (as well as some circular scribes for gauges, etc..).
The size of the panel that replaces the ashtray flip-out is 9"w x 3"h.
I then used M4 bolts / nyloc-nuts to mount with nylon spacer standoffs. 1/2" stand-off for the top bolts and 1/4" stand-off for the bottom bolts.
I also purchased a carbon-fiber fabric for interior upholstery from ebay (yes... ebay addict here). Then using spray adhesive, I covered the new panel. So that the carbon-fiber look would match, I also scuffed and covered the trim panel (climate controls, radio, etc...) with the same.
Turned out well I think. I mounted the pod to the left so that I have room to mount switches, accessories at a later time. Plans are to add an exhaust cut-out and the hella grill with the halogen lights. Switches for both will end up in the extra space to the right of the Gryphon.
Old Sat, May 1st, 2010, 05:11 PM
Very nice!
Old Sun, May 2nd, 2010, 06:05 AM
Looks great. Good job. Is it weird to look down there to read the engine parameters? I watch mine all the time and wouldn't want mine that low.
