Old Fri, April 30th, 2010, 08:40 PM
Be sure to keep the minimum pressure in the bags or they can pinch. I usually keep mine around 10-15psi when I am not loaded, or plan on hauling anything.
Keep a close eye on your parking brake cables as these can snag easily on sticks and branches. Also check to make sure the differential breather tubes are still intact and do not have any cracks, just in case you have any water crossings.
Other than making sure all the fluids are topped off you should be good to go.
Ohh.......you might bring a spare CPS and 10mm socket and ratchet juuuuust in case.
Old Sun, May 2nd, 2010, 01:18 PM
Robert6401's Avatar
If you don't already have some good offroad tires, get some. Duallies are notorious for being bad in dirt, so you'll want any advantage you can get. A winch wouldn't be a bad investment either.
Bob-
