Old Sat, May 1st, 2010, 04:11 PM
Punisher's Avatar
Punisher Punisher is offline
Punisher is on a distinguished road
Here's some pics of the finished project.
I used some 1/8" plastic sheets found on ebay. They're already scribed at 1/4" increments on the back side (as well as some circular scribes for gauges, etc..).
The size of the panel that replaces the ashtray flip-out is 9"w x 3"h.
I then used M4 bolts / nyloc-nuts to mount with nylon spacer standoffs. 1/2" stand-off for the top bolts and 1/4" stand-off for the bottom bolts.
I also purchased a carbon-fiber fabric for interior upholstery from ebay (yes... ebay addict here). Then using spray adhesive, I covered the new panel. So that the carbon-fiber look would match, I also scuffed and covered the trim panel (climate controls, radio, etc...) with the same.
Turned out well I think. I mounted the pod to the left so that I have room to mount switches, accessories at a later time. Plans are to add an exhaust cut-out and the hella grill with the halogen lights. Switches for both will end up in the extra space to the right of the Gryphon.
Before you try and beat the odds... make sure you can survive the odds beating you!
