Opps, my mistake, I also forgot to mention the files I was looking at, it was a DAC3/VOAA7P6(dad's pickup). Looking at those parameters the Max MFD is 100. Just seems to go against my thinking of one X input and one Y input with multiple Z values being a problem, I'm guessing the PCM has someway of picking, just don't know how. I'll likely just try setting the normalizer like normal before I re-burn that chip, maybe even have it both ways and see if there's a difference.
![]() So out of my curiosity I checked the files for my pickup, MLE1, and that shows a Mass fuel minimum of 80 and a max of 100. Does the minimum come into play or not?
Thomas H. '97 F-250 CCSB 7.3L Auto, Gauges, Modded H2E, 285/200% sticks, 7.3L IC, Stealth Dual HPOP, Pheonix chip '03 F-250 CCSB 6.0L Auto, Gryphon CTS, FICM tuning by PHP, Powermax |
That's something I don't know, Thomas.
You're right though about the DAC3/VOAA7 definition. I have that one in my Sniper stuff and it mimics the MFD map you posted. However, with my Minotaur, I use VXY2/VKAE3 and it is already "properly scaled" from the factory. That's why your screenshot had me puzzled.....I've never really looked at DAC3.
What happens when you transpose two maps with different normalizers?
What are the Normalize All, and Autoscale All functions do? |
From what I've tried, if you copy a map it will only copy the values. If the normalizers are different, I've found myself bringing up the normalizers and doing a "select all, copy, and paste" for the x and y normalizer. And if you load a second file up, looks like it will take the x and y normalizers from the first file. The other questions I don't know, and I still don't after tryin to monkeyin around with them.
Depending on the disparity of the map values as far as the normalizers go, you can end up with some pretty fishy stuff. Remember this? http://forum.gopowerhungry.com/21935-post11.html It will actually work out to the computer thinking WFO at 585 A/D counts. Hang on!!! Some maps aren't as sensitive to changes and will go unnoticed if the map values are transposed without fixing the normalizers.
Change the normalizers to make them the same, now values are not represented right. This is aggravating because I see no way to make different files "comparable". |
Two separate projects.
