Old Tue, June 1st, 2010, 11:47 PM
speotter speotter is offline
speotter is on a distinguished road
I did check it today and the dome light doesn't even come on when you open the doors. Door locks and remote open do not work either. I haven't put a voltmeter on the batteries yet.
Old Sun, June 20th, 2010, 02:17 AM
cartmanea cartmanea is offline
cartmanea is on a distinguished road
Does the FICM have a relay or just a fuse? I'm thinking its a relay, but not sure. Might want to check that out, symptoms sound like a relay going bad and not actuating every time.
Old Sun, June 20th, 2010, 02:37 AM
Well the drivers side battery was dead. The ground on the other battery was loose. Replaced the battery tightened the groud. The thing turned over but wouldn't start. Sent the ficm to swamps supposed to get it back on tueday
Scott
Tags
excursion, ficm, flash, hard start, harness
