Old Tue, June 15th, 2010, 10:57 AM
The error code 0xF1 can sometimes appear during programming.
Try this:
1. Leave the ignition key in the ON position.
2. Disconnect the Gryphon at the OBDII port.
3. Plug the Gryphon back into the OBDII port
4. After getting to the main screen, wait 15 seconds for needed parameters to be loaded.
If you still cannot program the PCM successfully, contact PHP for assistance. B
Old Tue, June 15th, 2010, 12:54 PM
PowaStroka PowaStroka is offline
PowaStroka is on a distinguished road
Oh man, I just had a wisdom tooth out! I am trying this right now.. Will report back..
Nevermind.. Still error code f1
This vehicle calibration is not yet supported. Check for updates, and call tech support if your version is current.
Why wouldnt this be current?!?!?
2002 F250 XC 4X4 Auto
Edge Evo sent in for a GRYPHON on 5/20/2010 Happy B day to me!!
4" turbo back MBRP (no-muff)
6637
08' aluminum diff cover
AIH delete
Old Tue, June 15th, 2010, 02:24 PM
Verify what the hex code is when you plug the Gryphon in. It seems to be a mix-up on Corey's part when we did two Gryphon upgrades.....it just so happens that the other customer got your hex code and you got his.
Please post your hex code so Bill can make sure that he gets the right ones on the server for you. (It will likely begin with TNAA)
We apologize for any inconvenience.
Old Tue, June 15th, 2010, 02:55 PM
TNAA7S5.HEX
Is this something that can be taken care of via the net? Or will I have to send the Gryphon in?
Thanks for the responses guys!
Brian
6637
AIH delete
Old Tue, June 15th, 2010, 03:38 PM
We can do it over the 'net and Bill will have an update through Pegasus tomorrow for you.
Old Tue, June 15th, 2010, 04:14 PM
AWESOME!
How is it done? I just down loaded pegasus, is there a certain procedure to do it?
Can't wait till tomorrow!
6637
AIH delete
Old Tue, June 15th, 2010, 04:51 PM
Go to the powerhungry website at gopowerhungry.com and click on the "support" tab. From there, go about halfway down the page for the drop-down menu of Pegasus.
Download and read the installation/users guide about how to use the update client. (Download both from the website)
I will be putting your programs together tonight and Bill will upload them to the server.
