Old Fri, September 24th, 2010, 03:13 PM
Also, if you don't completely FILL your tank with 93, you are running a mixture that has an octane rating somewhere in between. Longshot's advice to start with +1.5 degrees of advance is a very good idea in this case. (If you were "half and half", you'd be burning 90 octane gas.) Later, when you fill up again, you'll be a lot closer to a true 93 octane mixture.
Old Sat, October 2nd, 2010, 06:41 AM
Yea. Lovin the 93 octane. Set my gears correctly, tire size correctly, and advanced timing by 1.5 so far. And big time difference. Just did the 1/4 in 15.18 with a .76 reaction.
Might try to advance timing to at least 2.0, possibly 2.5 and try to get into the high 14s.
Defitanly should of done a 93 octane tune. Oh wells.
Next mod I get I will get 93 custom instead of the 87.
Old Sat, October 2nd, 2010, 08:15 AM
Be careful on that timing. Of all the changes you can make that is the one where you can have too much of a good thing. If you hear anything that doesn't sound right back off the timing. You will probably be hitting a peak soon though since you are making tweaks for 93 on an 87 tune.
