Old Thu, December 2nd, 2010, 11:43 PM
dmiertschin's Avatar
dmiertschin dmiertschin is offline
dmiertschin is on a distinguished road
Sorry about my typing I was in a hurry when typing the first two post.
On the bully dog I didn't think that adjusting the shift firmness and the WOT shifting were dangerous parameters to change. The Bully Dog programmer that I had doesn't seem like it's nowhere near as aggressive as the Edge is. I want to say that when you program one of Edges three levels in a truck that it changes its shift firmness without change the actual firmness in the custom settings. As for the Bully Dog did not do that, you had a choice between just stock or firm shifting and from experience the Edges shifting is a lot more firm without changing it than the Bully Dog's firm shifting did thats why I say I'm not going to change the shift firmness on the Edge. For the WOT shifting I don't just put it all the way up to highest RPM's the truck can shift at because then I would be really trying to blow up something, I put them maybe just a little bit higher then what the stock WOT shift points are.
For settings maybe I should rephrase myself, I"m just looking for good settings on the simpler parameters so I won't have to worry about harming my truck. Also, sorry it seemed like I'm trying to make my truck into a race car.
Longshot I know what you mean about people wanting to just make their truck as fast as possible as thats what I was doing but, I didn't want it to sound that way. I don't constantly hot rod my truck either when I say I race my friends sometimes thats maybe like three times in a year that I'll do something like that. And don't worry I'm the type thats going to come crying here or blaming somebody if something goes wrong with my truck because to me if something happens to somebodies truck it's their own fault and they should suck it up and learn from what they did wrong.
By the way this whole forum does have a lot of answers for a lot of things in it and yall are very helpful to a lot of people.
2005 F-150 Fx4 5.4L 3V 2.5in leveling kit with 295s nitto all terrains with a S&B CAI, straight pipe true duals, and a bullydog gas downloader.
Old Fri, December 3rd, 2010, 12:06 AM
Thats what I figured but I like to be blunt at times so there is little miscommunication. Even though you still have the edge, go to the website and download the gryphon manual for starters. It has some very good info about many of the parameters you have access to. You should also read the stickies in all the relevant sections...there will be a quiz later on comprehension.
Edit: Here is the manual
http://www.gopowerhungry.com/manuals...02004-2008.pdf
Also, just about every vehicle is different so what works for me probably wont work the same for you. Dont remember who but someone around here was getting their best speeds with the WOT fuel set to 1.6ish while my optimum setting is 1.3-1.5 depending on the weather. Performance at part throttle and WOT can also vary between vehicles and set ups. The only way to find your peak settings is to do your homework and make gradual changes. It wont be an over night deal but it is the safest way to go about it.
