The biggest improvement I made to help control the smoke was all in the ICP map. I needed to ramp up pressures much faster, and it worked VERY well. But, if you decide to do this, drop your base SOI map down a few degrees in the lower MFD range. Also, dont get crazy right off the bat with this, work your way up to it, too much - too soon can cause some drive ability issues. |
Cool, thanks for the input.
On the ICP/PW front I was thinking if I had it set at what ever ICP and PW I needed to get the idle I want I would start there. As I give throttle input have the PW raise first up to the desired max PW, say 2.5 or 3ms. Then from there just have the ICP do all the up and down to make the desired power. That way I'm always as peak ICP for the power level I'm looking for. I don't know if that's a good way to go about it or not. Am I off base here? Or on the right track? |
There is a lot more going on there than I will care to comment on, but the way I see it, you have it backwards......sorta.
I think you are better off getting ICP up to max ranges then start stacking on PW. For instance, my ICP is about tapped at around 1/2 throttle, then PW picks up from there. |
Ok that makes sense. I was just thinking being the ICP has by far the biggest range the PW would max out pretty quickly then the ICP would take over from there. But I think you're right on having the ICP ramp up first.
My lord Dave, what have you got me into.
Just read this entire thread and now im going to go back through and re-read, i could read this 10x and never get alll the info!
96' f350 on 35's stage 1's, custom tuned, built tranny, IC, modded IDM |
