After looking a the code, Load Previous Settings will load in ALL currently modified values including ones that were changed 2, 3, or more sessions prior. I'm not really sure if this was the intended design of that function but I can see where it would cause a fair amount of confusion.
After giving it some thought, I think I will look at revamping the custom options menus to eliminate some of the problem associated with it. One thing I will include is the ability to determine if a parameter has been modified and put a "*" next to it for visual aid. I think that will be a tremendous help for people making custom adjustments. I don't know when I'll be able to actually make the changes but will get it in as soon as I possibly can. I guess in the mean time, disregard the Load Previous Settings and just enter the modifications by hand and make sure all that is working correctly.
So it does hang on to past changes. Now if I can just figure out what I did in there the first time to screw it up I'm all set but for now I will be happy the way it is set up currently.
Thanks Bill. |
Fair amount of confusion is an understatement, Bill! I think maybe I'm catching a slight glimmer of what's happening though. It WOULD be nice to have the changes to the menu you are thinking of. I sure wouldn't spend time on it right away though if you have custom tunes for people hanging in the fire. (Unless, of course, you need a break from that task and you feel like a different challenge).
I'm still very puzzled about grizz's truck sounding like it was running rich at idle. How in the world could he have altered the idle mixture? And, if it wasn't that, what else would give those symptoms? ![]() - Jack |
Not a clue at this point. However, if he can recreate the issue I can look at the built custom file and see what happened.
To retrieve the file, plug the unit into the USB, run Pegasus and select [Utilities] -> [Retrieve Critical Files]. This will read the files from the programmer. E-mail me the CUSTOM file and I can see what's wrong. Hope this helps.
But, should this happen to anyone else, I'll try to keep it in my memory banks.- Jack |
There still is a problem. I can't change anything other than tires, gears and shift firmness or it will not work no matter how I change it. The last time I tried it would not even start until I changed it back. I am assuming you don't have to go back to stock first every time you change something on level 2. I have just been loading level 2 and making the changes before it loads (not using the load previous settings option).
The unit does say it is on 2 but other than the shifts being way to hard I could not really feel any significant power difference. I ended up putting the shift firmness down to -5, -5, -6 to soften them up and it still slams into gear between 1st and 2nd when I stand on it. I suspect this is because of my Factory Tech Separator Plate but I thought 0 would be factory stock settings is that not the case? Or does the level 2 add shift firmness and that is considered the new 0 and you adjust it up and down from there? If that is the case how much does it add so I know how much to take out? Will having the firmness that far in the negatives harm my transmission? As for running Pegasus, what are the minimum computer requirements? My home computer basically just keeps my desk at home from blowing away and is going to be replaced as soon as I can. Sorry to be a PIA but I am just trying to figure out what is happening here. Thanks. |
Bump for answers to the above.
