New Member Introductions
Closed Thread
Old Wed, December 22nd, 2010, 03:14 AM
Welcome, and just an fyi, Magnaflow has a DI/DO muffler with an x-pipe already inside it, so it might serve the same purpose and save you a few $$ , The only problem with exhausts in our trucks is that anything that is cat-back can only help so much... I dont know if the 4.6 is different, but the 5.4 has 4 catalytic converters, 2 per cylinder bank, and they are in series, so unless you get rid of one of those or replace both of them with some super high flow cats you will only get a limited amount of HP and mpg gains. but most people only do an exhaust for the sound anyways, so of course it is up to you. oh and btw removing a cat might be illegal in places, so I would check with an inspection guy or a cop or online to find out what the deal is. hope I helped!
Old Wed, December 22nd, 2010, 11:14 AM
kmgordo99 kmgordo99 is offline
kmgordo99 is on a distinguished road
Yea, I was looking around last night for exhaust stuff on here to see which one would run better with the Gryphon, and it seems that the SI/DO actually works the same or better than true duals? I was looking into true duals because I always thought that they helped out a little more. SI/DO would be a lot cheaper to run though.
Old Wed, December 22nd, 2010, 05:35 PM
Gryphon was shipped today...
Old Thu, December 23rd, 2010, 10:42 PM
sweet! no matter what exhaust you decide on the gryphon will work great! and yeah im betting that there wont be much of a difference between the exhausts whichever you choose
Old Sun, December 26th, 2010, 07:12 AM
60DRB's Avatar
60DRB 60DRB is offline
truck # 3
60DRB is on a distinguished road
From what I've been able to find out, the only significant performance gain in the exhaust department is from long tube headers. As noted previously, that will require removal of the cat-converters. While a tuner can correct/ignore that removal issue, the law won't (ignore the removal). Some states won't even know you did this (no inspections), and other states will quickly hammer you into the ground finacially with fines, etc. You may also have to re-install the cats to resell the truck later...$$$$
Most guys seem to just install noisy cat-back systems. My understanding is that if the pipes go straight out the back, when they floor the pedal the noise shock waves rebounding off my windshield actually add 15 HP to their butt dynos.
Now if the weather would just clear/warm up, I could get my brand new Gryphon installed...
Closed Thread
