Old Sun, January 30th, 2011, 12:07 PM
Originally Posted by Dark Rider View Post
can I adjust the tire size while im driveing to get the correct speed or do i have to stop and turn off my truck every time?
You have to stop to reprogram the truck so yes.
Old Sun, January 30th, 2011, 12:11 PM
Dark Rider Dark Rider is offline
Dark Rider is on a distinguished road
thanks
Old Sun, January 30th, 2011, 03:35 PM
I dont have lvl ground to check the distance for tire size and i am run 35 12.50 17 tires but the 12.50 is not a ratio so how do i fugure the tire size?
Old Sun, January 30th, 2011, 05:26 PM
being that the Gryphon wants the circumference that is 2*pi*radius, so it should come out to about 109.96 inches, which turns into 279.29 cm, which is 2792.88 mm, then times that by .97 gives you 2709.1, but since your gryphon cant do the .1, enter as close to 2709 as possible and you should get a fairly accurate speedometer.
The other way to figure it out is to find out how many revolutions per mile that your tires make and then divide 1609344 (mm per mile) by that number and you should get pretty close to 2709 but with less calculations, kinda like bill says on this page.
Hope that helps!
Old Mon, January 31st, 2011, 12:36 PM
Nicely stated, ticopowell!
