Old Wed, April 6th, 2011, 03:24 PM
So the codes don't happen when the truck is at stock?
Only when the tune is loaded?
I'll do some more digging....
Old Wed, April 6th, 2011, 03:42 PM
dixiefishing dixiefishing is offline
dixiefishing is on a distinguished road
Yep - when at stock setting - no codes.....when programmer is installed on level 2 - i get the codes....Im at a loss. The shop that has the truck right now is also at a loss. They are stumped. When running in level 2 - driving around 50 -60 mph (1500 - 2000 rpm) the truck surges and misses and I get the DTC's - CEL never comes on - well it does if I continue running it like that - or if in park or neutral - and revving the rpm to 3000 or so and holding it - the truck misses - you can feel it and hear it - when you let off the throttle - the truck idles rough - thats when the codes come up. The shop said it did it all last week just like that - like it had been doing with me for so long - they did all that work and took the truck back to stock and since then no codes - nothing. Hooked it back up and to level 2 today and boom within a matter of minutes - codes were back and truck was missing.......Im confused and very frustrated.
Old Wed, April 6th, 2011, 09:41 PM
Dixie - I responded to this on f150online. Please try the Level 1 (Tranny Only) tune. I want to verify that it really is the tune that is causing the problem. And, you probably MUST call Edge if it is.
I also suggested a couple other steps in f150online too.
Old Thu, April 7th, 2011, 07:37 AM
OK thank you - I will do it tonight. I picked the truck up last night - and sure enough on level 2 it started the codes. I set it back to stock and the truck ran great and has been running great. But now the edge reads a dtc on stock setting - P1000 OBD readiness test not complete. It will clear out - but will come right back. I took the edge in to use my Fusion software to try to upgrade it - which it did upgrade and re calibrate. Took it back out and installed it at stock setting and still the P1000 code. I have not reset it back to level 2 - so I am really thinking it has to do with the edge itself. I will set it to 1 tonight after work and see what happens.
Old Thu, April 7th, 2011, 08:32 AM
The P1000 is normal for any time you do a flash programming event on the vehicle. However, aftermarket tuning usually disables that code....returning the vehicle to stock will set that code every time; it's normal.
Old Thu, April 7th, 2011, 08:43 AM
Oh ok - I will set the truck to level 1 tonight and see if any of the ignition codes appear. I hope by doing the edge update and re calibration that maybe things are cleared out and it will go back to normal. I guess I will see tonight.
thanks for all the help guys!
Old Thu, April 7th, 2011, 02:46 PM
If its tune related contact edge.....
