| 2009 to 2014 F-150 3.5L, 3.7L, 4.6L, 5.0L, 5.4L, and 6.2L equipped F-150s. |
Cleaning the throttle body might help. Also look at your maintenance log for when you last replaced the fuel filter. Supposed to do that every 15K. I noticed my truck got quite a bit faster after I changed that out. The filter was absolutely disgusting, I dont know how it even ran.
How easy is it to change out the fuel filter. Is it something a novice person like myself can do. Is there an article on how to specifically clean the throttle body and what stuff do you use. Im sure you have to becareful on how you do it and what you use.
40 series Flowmasters, K@N CAI, Jet MAF, Troyer Under Drive Pulleys, Stainless Works Longtube headers/Hi Flow CATS w/X-pipe, Ram Air Hood G-Force, SCT X3 programmer with custom tunes |
The fuel filter in the 09-10s (and probably 11s) is not user serviceable (it's in the tank).
Unless you over oiled your K&N, your MAF and throttle body shouldn't need to be cleaned. I'd suspect winter blend gas is still being sold in your area or maybe there's more alcohol content (E10).
"Good judgement comes from experience. Experience comes from bad judgement." - Colin Powell to new batch of 2LTs (while serving as V Corps Commander) Factory manuals here: http://www.motorcraftservice.com |
Probably got one fill of summer gas then stumbled onto another fill of winter gas.
I was actually at the gas station today and noticed it said 10% ethanol content. I was actually looking because it was mentioned on another forum. would it be worth me getting my tunes redone to accomidate the 10% ethanol mix. I didnt mention it when bill did my tunes. Or does he normally take that into consideration.
I think there was a government mandate that all gasoline had to be at least E10 by a certain year so Bill has been writing them to accommodate for it. Since these engine are low compression, however, there isn't much that needs to be accommodated for.
