Old Mon, April 18th, 2011, 10:29 PM
Medic150 Medic150 is offline
Medic150 is on a distinguished road
im on a mac, for what ever reason, the video doesnt come up for me...
Old Tue, April 19th, 2011, 03:07 AM
str088 str088 is offline
str088 is on a distinguished road
What video? The one from Edge on how to install the pod and the programmer?
Old Tue, April 19th, 2011, 09:10 PM
Just wanted to update everyone, I got the programmer today (a day earlier than
expected) and the installation was a breeze. Now I just gotta wait for the custom
tunes and I'll be all set. Also the package came with a cd to install pegasus and
worked out better than when I tried to do it online. Thanks all for all your help. Also
they sent candy which was cool. Just a few more question where can I find how to
put the custom tunes into the programmer and a guide for pegasus use. Thanks a
lot guys for the support.
Old Tue, April 19th, 2011, 10:16 PM
So, you have the Monochrome Gryphon? You use Pegasus with that model.
Go ahead and play with your toy in your truck to your heart's content. When you are told your custom tunes are ready, set your truck back to stock and plug your Gryphon into the PC with Pegasus running. The Gryphon screen will change from red to green when it "connects".
Then, click on [Updates]->[Download Custom Tunes] and follow the instructions. When finished, unplug the Gryphon from the PC and return it to your truck.
Turn the ignition ON, then plug the Gryphon in. From this point, you should be able to load your custom tune into your truck's PCM.
Old Wed, April 20th, 2011, 02:11 AM
Yeah I got the regular Gryphon PHP and yeah the pegasus program that
came on the disk is so much better than trying to install it from the site.
No errors or anything which was awesome.
So I got a question, how do I put the truck back to stock? I was kind of
trying to look for it while playing around with the programmer and couldn't
find the "reset button" to put it back to stock. I'm guessing it's where the
canned tunes are. Also how does pegasus work? When the custom tunes
are done do I just go on pegasus and download it? Or is it going to be
where I put my hex code in the forum to dl? Thanks for your help. I must
say this programmer is sweet.
Old Wed, April 20th, 2011, 11:47 AM
Str088 - if you look at the Power Programming menu on the Gryphon now, you'll see there is a "Return to Stock" choice. If you select that choice, the Gryphon will reload your stock tune into the PCM and the Gryphon will display a zero "0" in the upper right corner of the Display Screen.
Pegasus is able to access a server at PHP. With your Gryphon connected, it reads the Serial Number (S/N) and then looks in the server for tune files with that S/N when you click on [Updates]->[Download Custom Tunes]. If it finds those tunes, it asks if you want to install them. You just click on "Yes".
Old Thu, April 21st, 2011, 06:18 PM
I see, cool. I found where the stock program is at lol. All I need to do is play
with the programmer. So I had a question about how long it takes for the
custom tunes to be completed? I ordered two and wanted to know if you guys
how long it took for yours so I can make a time frame for myself. Thanks guys.
