Old Tue, April 19th, 2011, 01:32 PM
God & Guns
Just guessing, blown injector gasket, bent push rod, valves not seating all the way. My uncle said he has a blown injector gasket because of all the gunk built up around that injector. Any truth to that...
I think I have the same issue (minus the white smoke) and I JUST replaced the cps with the black one from riff raff. I'll see how it runs when I leave work. It did stumble under light acceleration, but pulls very good under firm acceleration. So just in case I'm doing pricing for rocker arms, push rods, and valve springs.
My uncles 99 F250 did puff out clouds of white smoke under normal accleration but would clear up if he got on it. Then he went to start it one day and you could hear a open vlave. He pulled the valve covers and a push rod (or half a pushrod) was laying on top. After he replaced that one, another one broke and a rocker arm. So he just replaced every one of 'em.
Try running some tests on the engine and see if you get any codes...that'd be a good place to start.
Old Mon, April 25th, 2011, 01:36 AM
Does anyone have a video of a 7.3 idling with air in the fuel lines? Im wondering if i have a leak in the fuel line and thats why it idles funny. Just a guess. I did the fuel tank mod and it has a inline filter.
Old Mon, April 25th, 2011, 11:57 AM
God & Guns
After I installed a new black cps my truck ran much better, but now its back to its old ways...stumbling on accleration and a miss at idle. I unpugged my ICP yesterday and the miss at idle was even more noticeable. So I'm thinking IPR or IDM. Have you tried letting it idle with the ICP unplugged? Maybe we have a related problem.
I'm buying AE from PHP next month and hoping it can help me find the issue.
Old Fri, July 15th, 2011, 08:04 PM
Ok finally pulled my injector Rosewood diesel will inspect my injector even though my warranty is up. While everything is open what do I need to look for. What am I looking for in the cups etc. I started the truck up with the valve covers off and there was good blowby that I could see. What is expectable etc. Anyone have a video?
Old Fri, July 15th, 2011, 09:50 PM
Acceptable is when you can remove the oil fill cap and you don't see individual "puffs" of crankcase vapors.
The pressure of the vapors should not be enough to lift the cap off of the filler tube when placed upside down. It may vibrate off of the filler tube, but it shouldn't be blown off.
Old Fri, July 15th, 2011, 11:15 PM
Ok then its fine what am I looking for in the injector holes?
I spoke to Rosewood he thinks its the tuning but will check the injectors for me
Old Mon, July 18th, 2011, 08:09 AM
God & Guns
And what is there is enough pressure to lift the cap? I was at the dealer a couple of months ago to do the brake sensor recall and I asked him (the diesel tech) about my idle. He said it was from cylinder wear due to a "bad" filter (AFE). He then pulled my oil fill cap off and showed me the crank case vapors...it looked enough to lift the cap but I haven't tried..yet.
