Old Sun, April 24th, 2011, 09:09 AM
cj45lc cj45lc is offline
Originally Posted by screagle07 View Post
I just got my FU chip installed today. What a difference in performance. I was running the 100 performance tune leaving a stoplight and got on it pretty good. I got some turbo surge and was wonder would a ww help this and would this still be considered a mild mod for my FU chip? BTW, love the chip so far.
W-W took care of my surge & quite a bit cheaper than a ported housing.
Old Sun, April 24th, 2011, 11:57 AM
Grizzly11 Grizzly11 is offline
Grizzly11 is on a distinguished road
yes ww should take care of most of the surge im lucky and havent seen it yet knock on wood what kind of egts are you seeing in 140race?
Old Mon, April 25th, 2011, 09:28 AM
Normal temps.
More power, more fuel. More fuel, more heat.
Old Mon, April 25th, 2011, 09:31 PM
In 140, I get 1200-1250 tops. Have a 4" dp with 5" exhaust. Haven't seen 1400, and I've romped on it. I see 600-800 drinving normally.
SHAWN
Old Mon, April 25th, 2011, 09:58 PM
would a stock exhuast cause temps to be that high bc im seeing 300 more than most or could the truck have upgraded injectors?
Old Tue, April 26th, 2011, 08:32 AM
Highly unlikely that you have modified injectors if the tuning works fine......
There are a lot of things to take into account here:
Ambient temperature
Elevation
Fuel quality
Engine mechanical condition
High pressure oil system "health"
Vehicle weight
Boost/drive pressure leaks
The best thing to do in your case is to put in a straight-through muffler on the stock exhaust system as it's plenty big to support stock injectors and it won't cost you an arm and a leg. My 2000 has a muffler from a 1995-1997 PSD and it's quiet and it was free. The downpipe is stock....at this point, it's certainly not hurting anything.
Old Wed, April 27th, 2011, 06:53 PM
its already straight cody did you or bill ever find anything out on that switch
