| F.U. Chip & FU2 Flex Chip (DISCONTINUED) (Disabled) If you have a question or comment relating the new F.U. Chip or FU2 Flex Chip, post it here. |
Check your burner power relay. Over-zealous installation of the chip into the burner can dislodge the relay and cause you this exact problem.
i checked that and it is intact where is should be
2000 Powerstroke (PMT1) 4x4 auto XCSB |
If your relay is in fact where it should be, your switch is in the first position, and you are getting "FF" for CID, it's likely that it's fried.
so i need to buy a new chip?
You can send us yours and we will tell you if it's fried or not for sure. However, if the CID says "FF" even if the switch is in position 1 and the power relay on the burner is intact, I'd say you need to buy a new chip.
