Old Mon, April 25th, 2011, 09:28 AM
Normal temps.
More power, more fuel. More fuel, more heat.
Old Mon, April 25th, 2011, 09:31 PM
In 140, I get 1200-1250 tops. Have a 4" dp with 5" exhaust. Haven't seen 1400, and I've romped on it. I see 600-800 drinving normally.
SHAWN
Old Mon, April 25th, 2011, 09:58 PM
Grizzly11 Grizzly11 is offline
Grizzly11 is on a distinguished road
would a stock exhuast cause temps to be that high bc im seeing 300 more than most or could the truck have upgraded injectors?
Old Tue, April 26th, 2011, 08:32 AM
Highly unlikely that you have modified injectors if the tuning works fine......
There are a lot of things to take into account here:
Ambient temperature
Elevation
Fuel quality
Engine mechanical condition
High pressure oil system "health"
Vehicle weight
Boost/drive pressure leaks
The best thing to do in your case is to put in a straight-through muffler on the stock exhaust system as it's plenty big to support stock injectors and it won't cost you an arm and a leg. My 2000 has a muffler from a 1995-1997 PSD and it's quiet and it was free. The downpipe is stock....at this point, it's certainly not hurting anything.
Old Wed, April 27th, 2011, 06:53 PM
its already straight cody did you or bill ever find anything out on that switch
Old Wed, April 27th, 2011, 07:07 PM
Not yet. Haven't been able to get ahold of anyone at TS for two days.
Old Wed, April 27th, 2011, 07:50 PM
ok thanks cody
