Old Wed, May 4th, 2011, 12:21 PM
Thanks, Longshot - exactly correct. But I'm not certain Medic150 understands. The Rev Limit (RPM Limit?) is a SINGLE value that is one of the menu choices in the Custom Options Menu. I think it MAY default to around 5300, which would be too low for a WOT upshift from 2-3 set at 5000.
Setting these values is pretty easy, but read through this: http://forum.gopowerhungry.com/faqs-...ions-menu.html (making sure you understand it) before you do. You WILL have to manually set your Tire Size (TS) and possibly your Gear Ratio (GR) if you open that menu.
