Old Sun, May 29th, 2011, 11:41 PM
ToMang07's Avatar
ToMang07 ToMang07 is offline
That guy...
Ok, so I learned I was doing the KOER Switch test wrong, so I did ALL of them again. Here was the results, second round:
1: (GEM/Central Timer)
B1483 Brake Petal Input Circut Failure
P1832 Transfer Case Differential Lock-up Solenoid Circut Failure.
2: (Hybrid Electronic Cluster)
U1262 SCP (J1850) Communication Bus Fault -
U1027 SCP (J1850) Invalid or Missing Data for Engine RPM -
B1352 Ignition Key-In Circut Failure -
C1710 RT Rear Center Sensor Circut Fault -
C1704 RT Rear Sensor Circut Fault.
KOER CCT: P0269, P0284. ( I believe to be related to Grey CPS)
KOEO: P0605 PCM ROM Test Fault, (From the Phoenix, right?) P1218 CID High. ( I believe to be related to Grey CPS)
KOEO Injector Buzz Test: P1218 CID High. ( I believe to be related to Grey CPS)
KOER: OK.
KOER GP: OK. :
KOER Switch: OK.
