Old Mon, July 18th, 2011, 01:12 PM
We have files in the FU library that are already set up for BTS/JW/Trans-go modifications that reduce the line pressures and soften the shifts up a bit.
I have modified your file list to include the tranny files. They will be clearly indicated in the list and isolated from the standard files.
Old Mon, July 18th, 2011, 07:23 PM
screagle07 screagle07 is offline
screagle07 is on a distinguished road
Cool, thanks for the quick response. I love the way the truck runs and I'm getting about 5 mpg better on the 120extreme over stock. Thanks for the great product.
Old Tue, July 19th, 2011, 11:56 AM
Definitely our pleasure.
Old Wed, July 27th, 2011, 09:08 PM
I re-burned my chip with the new files for the Trans-go shift modifications and have to say I like the original files better. In the higher settings, I get short shifts and a shooshing sound when it shifts into overdrive. Not sure what this is, I hope it isn't the tc slipping. I might just be paranoid since I just had my trans rebuilt too. I am going to re-burn my chip with the original files and get in touch with the guy that rebuilt my tranny to see what else he may have modified. I think he may have modified the valve body as well. I will post again after I figure out exactly what he did and what is going on with my trans. Thanks for all the help and I will let you know what I find out.
Old Wed, July 27th, 2011, 10:28 PM
The "shoosh" you're hearing is from the turbocharger. The engine RPM is dropping quicker and the drive pressure on the turbine side of the turbo goes away thus causing the boost pressure to come back out through the compressor inlet. No biggie.
