Old Sun, November 20th, 2011, 02:16 PM
If you are going by height I'm assuming you have a CS/CTS?
I'm gonna guess somewhere around 2600mm circumference or 83.3 cm in diameter (32.8 inches). If you have a GPS, clear both odometers and drive at least 10 miles. Then enter the values as shown.
Truck Odometer / GPS odometer x (the tire size you've had entered)= new tire size
Old Sun, November 20th, 2011, 02:21 PM
sblue sblue is offline
sblue is on a distinguished road
I have the original edge/gryphon.
I also don't have a gps, I do however have a gps app on my iPhone. Will that suffice?
I've never entered any tire size figures in my gryphon, does it already have a stock number for me to work with in it?
If so how do I find it?
So what I would do is reset my trucks trip and start a new trip on my iPhones gps travel for at least 10 miles?
Once I have my figures what do I do then? I'm sure they will both be different.
Old Sun, November 20th, 2011, 02:22 PM
Another thing is when I have the right figure and am ready to input it into my gryphon will I delete my custom 87 performance tune?
I have to make the change in that setting right?
Old Sun, November 20th, 2011, 02:24 PM
I wish there was an easier calculator that would give you how many mm you should adjust for per inch of tire you change.
Is driving 10 miles the only way to do this?
Sorry guys, I'm sounding like a total knob. As you can tell in clueless.
I cant even find out how to see what the stock tire size is on my gryphon?
Totally lost and just might throw in the towel and let it be.
Old Sun, November 20th, 2011, 03:05 PM
Yeah, the Iphone will work. You can also go to google maps and get directions from one place to another. If you did not enter your original tire size then program 2400 for the tire size, drive, then do your calculations. Doing this will get your tire size within a few mm.
Another way is to mark the ground and your tire, roll forward 3 rotations, take the length (in meters) and divide by 3. That will give you one average circumference. Then multiply by 1000 to give you mm.
You can't really add a number of mm of circumference for every inch of diameter because different tires have different attributes. Also, tire pressure will have a large influence.
Old Sun, November 20th, 2011, 03:16 PM
Thank you for all the help long shot.
Going back to my first post. If nothing has really changed between my trucks speedo and gryphon should I even bother?
Old Sun, November 20th, 2011, 03:24 PM
They both use the same value for their speed calculation. If one is off they are both off. The needle on the truck is designed to be about 2 mph off at 70.
Old Sun, November 20th, 2011, 08:07 PM
Since you have the original Gryphon, you should have downloaded Pegasus. Pegasus has a "Gear Ratio Calculator" that can be used to determine your Tire Size (including squish). Click on "Calculators->Gear Ratio Calculator" to start this application. Now, enter your tire information this way: "305/55-20" (notice the "dash" before the 20) in the "Old Tire Size" box. The application is set up to apply a "rubber squish" value of 5% (you'll see that in the "squish" box). Once you've entered your tire's numbers, you'll see a value of 2596mm in the "Old Circumference box. Use that as a starting value - I think it's going to be nearly perfect and you'll note it is almost the same as the 2600mm figure Longshot gave you. (4 mm is less than 3/16 inch, by the way.)
Your 55-series tires don't really "squish as much as the more narrow aspect ratio ones. For those, I'd change the value in the Squish box to 7%.
As Longshot said, the truck's speedo and the Gryphon will always be different by the same amount. They're both getting the same information from the PCM, and the truck's speedo just has a "high side error".
You won't change your custom tune by correcting the Tire Size. Just open the "Custom Options menu" when given the chance and then scroll to Tire Size and enter it. Hit <Enter> to save it. Then, scroll to Gear Ratio and change that value to whatever your axle ratio is (if needed). You may not have to change anything there, but you need to check it. Again hit <Enter> when it's correct. Then scroll to "Done" and hit <Enter> to start programming.
Old Sun, November 20th, 2011, 08:39 PM
I went on php and printed out there gryphon manual/instructions.
On pg. 15 is a calculator on how to do this. So I plugged in my stock tire info and got 2483 (this is with the pho squish factor of .97) I also plugged in my new size (305/55/20) and got a reading of 2570.44
So if my 20"s give me less squish factor should I multiply by .98 instead, would that be about 7% ?
This would give me a reading of 2596.94 (2597)
So one last time to sum it up guys, I go to my 87 performance tune, hit custom options, scroll to tire size and enter either 2570 or 2597 (depending on which is more accurate for squish) hit enter then scroll to gear ration and ensure it says 3:73 and then I'm done?
I realize this isn't done with a gps, but this will get me closer to accurate than what I have now right?
Old Sun, November 20th, 2011, 09:19 PM
Just to make things easier i think I'm going to to with the value I calculated on the gryphon instructions of 2570
I believe that's with a 5% squish factor
I'm not sure how to use a 7% squish factor with my 20"s? Would 2596 be more accurate?
