Yes they are, but also check out the Terminator hpop.
01 F350 7.3 4x4 CC SRW/3.73/315-75-16/Aeroforce Interceptor/BD Thruster II/ Bellowed Up-Pipes/4" turbo back exhaust/CCV Mod/DIY 6637/FPR Shimmed to 65 PSI/TS chip reburned with PHP tunes (Stock, 40T WITH Whsiper tune, 80DD, 100R, 140Ex, 140SS)/Replaced and Cleaned EBPS & Tube 4-6-12/Zoodad mod/Recon smoked cab lights/MM Hubs/Cowl Hood/HPx |
.....and if you're chasing a low injection pressure problem with a stock pump and AB/AD injectors on a "hot" tune, don't be surprised if neither pump gets your pressure where it's supposed to be.
Feel free to elaborate...
02 F-350 Super Duty SCSB 4x4 SRW 7.3L TD, DIY-I, PHP-6 Phoenix, 4" Turbo-Back 409 MBRP, Glowshift 3 in 1, Fisher 8' MM2 "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery." |
Oil usage is determined by intensifier piston area, plunger travel, and nozzle size.
Basically, split shot injectors waste a good bit of oil because there is a period of the injection event where oil is being used but no fuel is being injected. Couple this with a relatively small volume of fuel to begin with and the excessive injection pulse width that is required to empty an AB or AD injector and you have injectors that KILL HPO. There aren't problems under normal usage to tunes <80 HP in most cases. However, tuning that maxes out the injectors' capability (100 HP or so) really begins to show shortcomings because of this issue. That's why hybrids and singles with larger nozzles are da' bomb. Hybrids have a smaller intensifier piston (basically use about 72% of the oil volume that stock injectors use per given amount of plunger travel) and larger nozzles allow a greater amount of fuel delivery in a given amount of time compared to stock nozzles. 300 RWHP with stock nozzles on stock injectors is WAY different than 300 RWHP with larger nozzles as far as the tuning is concerned.....and that USUALLY results in the ability of a HPO system to maintain pressure above and beyond what's possible with stock splits. |
I just bought this truck about a year ago and I'm still shaking it down + going thru a giant learning curve as this is my first diesel anything. The truck just went over 300K and seems to be sound but a little weak in the hp area. Didn't know about the early 99 thing till after I bought it. I had the injectors out last winter and replaced one that was questionable with a factory reman. The tags on the injectors didn't say reman on them so I'm taking it for granted that there original. So if I upgrade I should be looking at single shots?
are they noisier than double shots? and how does the idm fall into the mix? 110v vs. 220v. I was also looking at a ballbearing turbo setup from turbonetics but that's quite away down the pipline. Did I say I love my truck. Well I do. |
no the tn kit is a garret bb three different sizes to choose from includes the pedistal all the piping hoses and hardware. actually it looks like a very well put together kit all the piping is stainless stee and it also has the flex up-pipes in stainless. They also sell an aftermarket intercooler that's supposed to flow gobs better than the factory unit.
Ford Powerstroke for 2500.00 it looks like a good deal. I want to trick this thing out a bit and make some really decent power. Like around 400hp. Give me the lo down on how to get there. I think though my next upgrade is to install 3:55 gears and a posi. |
