Old Sat, March 3rd, 2012, 11:47 AM
Originally Posted by flavtfan View Post
when changing between custom tunes...if i've done any changes to the custom tunes, do i have to load previous settings everytime i switch between those custom tunes to keep the changes i made? i currently have the 87 tow and performance and made minor adjustments to tire size and shift firmness only. thank you and sorry if it's a repost but i searched for a while and couldn't really find clarity on the subject.
Yes you do. Anytime you change tunes, if you have "customized" settings like Tire Size that you want to keep, you must open the Custom Options Menu and then IMMEDIATELY scroll to and select "Load Previous Settings". That will reload those values. Then you can scroll to "Done" to start programming your PCM.
If you don't do this, those customized settings will not be loaded.
