Old Tue, May 1st, 2012, 10:29 PM
Originally Posted by Highbeam View Post
1) From what I have read here, whisper mode can be blended with all tunes for quieter idle. Is there a negative side to this? It idles slowly and slightly quieter when warm. Does the whisper tune wash lube from the cylinders, damage injectors, high fuel consumption, any side effects at all? Extended idling periods are probably not the best thing in the world when idling quietly, but the couple of minutes most people spend in drive-through windows won't hurt anything.I realize that it won't whisper until fully warmed. Is there an additional cost to adding whisper to all my driver tunes? No.
2) Is the 65 HP tow tune (7500-10,000#) the proper tune to get for high reliability towing my 8000# RV trailer? You can use it (as that's what the website says).or should I get a conservative 40 HP tune? Do the tow tunes cause EGT problems? This is the #1 reason that different power levels are available. Higher horsepower levels at sustained high load will experience higher EGT.
See replies in red.
Old Wed, May 2nd, 2012, 02:32 AM
Old Wed, May 2nd, 2012, 10:58 AM
Highbeam Highbeam is offline
Highbeam is on a distinguished road
The whisper tune is starting to scare me a bit after seeing the youtube video from PHP. Seems the idle drops way down and with you folks suggesting that it really isn't a good idea to idle for more than a minute or two I don't know that I want it on all of my driving tunes. I really want quiet and I think that there is some real potential to improve all diesel tunes by knocking down the noise level at normal idle speeds. For me it is not about the drive-thru, I refuse to use the drive thru for several reasons.
Knowing that I will be in traffic, at night in the rain, running my lights, wipers, defrost blower, maybe stuck at a stop light for a few cycles, will the whisper blend create a charging issue? An oil pressure issue? nasty exhaust issue?
I am trying to decide between applying whisper to all driving settings or just applying whisper mode to a second 80dd setting. So I would have two 80dd settings, one with whisper.
Oh and after reading this forum some more it appears that you folks can blend the no-start setting with hi idle so I can start the truck and then flip the switch to the no-start setting and get hi-idle but if the engine is shut off, it won't start in that setting. Great idea! Saves me a slot.
I pulled my PCM code last night without pulling the PCM. NVK4 just like it was supposed to be. My daughters' toy makeup mirror really came in handy.
Thanks to you both for responding to this thread, it means a lot.
Old Wed, May 2nd, 2012, 11:59 AM
Yeah, I wouldn't do Whisper in ALL my programs, just one or two where you can select it. That's why we've used it as a standalone program for so many years, it just works easier that way.
The no-start/high idle seems to be growing in popularity. It's a good way to utilize a single space, unless you shut the truck off and forget you're in the no-start program. That's always fun.
Anyway, let us know if we can provide any further advice.
Old Wed, May 2nd, 2012, 01:33 PM
Thank you for the prompt answers. I ordered just now but specifying the blended tunes is a little tricky. Just in case I wasn't clear....
stock
65 tow
80dd with whisper idle
80dd
100 perf
no start with 1100 high idle
Happy birthday to me!
Old Wed, May 2nd, 2012, 03:04 PM
Fair enough! We'll get 'R done.
Old Wed, May 2nd, 2012, 11:40 PM
Late in this thread but what i"ve noticed in whisper(I have it as a stand alone tune) is that theres definitely some raw fuel coming out the back end...otherwise it doesnt hurt anything for a few mins as said..
DIY intake
CCV dumped
Autometer gauges
WW/ATS 1.0 exhaust housing
AIH delete/ebpv delete
TruCool trans cooler
Straight piped
PHP FU
Old Mon, May 14th, 2012, 01:36 PM
stock
65 tow
80dd
100 perf
So, it's been 10 days and I haven't heard anything or seen anything. Not wanting to start the phone game, what kind of timeframe are we seeing these days before I should start worrying?
I've been doing a lot of towing and can't wait to feel the power.
Old Mon, May 14th, 2012, 06:34 PM
Great news, I received the invoice via email. Should ship after the end of the week.
Old Wed, May 2nd, 2012, 11:46 PM
Sounds like you need to drive a gasoline-powered vehicle (or something other than a 7.3L) instead.
