Old Wed, May 2nd, 2012, 03:35 PM
God & Guns
Also, I saw someone that ordered a FU chip with no "Stock" position. Don't ya'll reccomend having a stock position on the chip? Is there any danger of turning the truck off with an aftermarket tune, removing the chip, then turning the truck back on running strictly off the PCM?
Seems like you could get one more tune in that way. If you have to diagnose the truck, its no big deal pulling the chip out if the PCM casing hole is big enough.
