Old Wed, May 2nd, 2012, 07:25 PM
DocBar's Avatar
DocBar DocBar is offline
DocBar is on a distinguished road
Look up some sites like xtreme diesel performance and get a 3 or 4 gauge pillar set up. Transmission temp, boost and pyrometer are a very common set up. You should also consider installing a regulated return fuel system. The TS 6-pos. chip is what I like. I've used SCT and EDGE programmers. I still use an SCT to scan for codes.
Watch out for the power bug. Once it bites you, 7.3's get e-x-p-e-n-s-i-v-e!!
2003 CCSB 4X4
Competition level 7.3L with all supporting mods, 38R trubo, BTS transmission, 250/100 injectors and Newton traction bars.
13.496 @ 100.43 mph 1/4 mile with severe tire spin (pre-traction bars)
Old Thu, May 3rd, 2012, 08:12 PM
God & Guns
My input on gauges is the AeroForce Interceptor. Yes ive been having problems with mine, but I have to give props to their customer service. It is currently sent off for warranty repair (hopefully replacement). But the concept of it is awesome. It is the size of a gauge...like the 2 1/16" gauges. But it plugs into the OBD2 port and reads available pid's. It can also take 2 aux inputs for egt and boost. Boost is available through the MAP sensor, but as mentioned it is only accurate so far. The auxillary boost gauge is mire accurate up to 100psi. You could also put the 2 aux inputs on a switch to switch to another aux input. Just change the slope and y (or x?) intercept in the aux gauge set-up screen.
It also has an anunciation (spelling) option. So if you don't want propane or water/method to be injected until 10psi, when it senses 10psi it will send current to the relay to engaged the propane or water/meth.
It can pull/clear codes, run injector buzz test, and cylinder contribution test.
When my gauge comes back I should have all of the aux sensors and components needed to read egts and boost.
