Old Sun, May 6th, 2012, 07:21 AM
Turbos tend to be more efficient in terms of output vs parasitic loss. Outside of that...
Turbocharger advantages:
Less expensive
Easier to maintain
Boost level controllable by wastegate
Supercharger advantages:
Linear power output
Easy to install
If I were to choose, I'd go turbo even though the systems are a little more complex. However, since you're running full duals it might be cost prohibitive to try to run a twin turbo setup. That's up to you, though.
Good luck with your decision.
Old Sun, May 6th, 2012, 01:52 PM
NITEMARE07 NITEMARE07 is offline
NITEMARE07 is on a distinguished road
So how much boost would be too much for a stock motor with twin turbo? I'm thinking somewhere in the neighborhood of 8 pounds. I like the idea of turbo because most guys run superchargers and of coarse that unmistakable whistle they produce. So even though superchargers put out 60% extra hp, turbos provide more! That would be some serious muscle.
