Got my Gryphon and updated it on Pegasus. With the Evo I always monitored the voltage, TCT, EOT, and ECT. Since the upgrade I can no longer see the trans temp???? Also noticing that the Gryphon freezes up when attaching it to the truck for the first time and before any programming is done. Cycle power off than on and the display comes on after acknowledging the warnings. I did unplug and plug back in the programmer, and reloaded the prior firmware update to see if it made a difference, no change. Any ideas?
Have no problem going to a box performance tune. Thanks in advance, Dave |
First: Return the truck to stock.
Second: Run Pegasus, go to [Updates] and then select [Custom File Download (Internet)]. This will download a corrected firmware that will fix the TFT issue. Take care.
Hey Bill,
got An "Internet Error Encounter" I'll double check the firewall and try a couple things. Keeping you updated. dave |
No luck, any other things I can try????
![]() ![]() ![]() Dave |
Pluged in the Gryphon into the computer (Pegasus) and said an update is available. So I did. Now looking at the website I see that I souldn't have done this. Now lost the trans temp on the display again and was wondering if the custom tue is gone. Let me know what I have to do to get this back. Thanks
Dave Vasser |
Dave - the custom tune should still be there, since you use Pegasus.
With your truck's tune reset to stock, plug the programmer back into Pegasus and click on [Updates] -> [Custom File Download (Internet)]. This should restore your custom tunes and the fix that Bill created. Make sure your ignition key is ON (engine off) before you plug the Gryphon back into the truck. - Jack
Hello Jack,
Tried that, got An "Internet Error Encountered". fire walls were off/ internet has great connection. Had this problem before. got both windows xp and windows 7, both with same result???? Any ideas???? Dave |
Even droped the firmware back a revision. No Luck.
- Jack |
