Old Wed, March 18th, 2009, 06:25 PM
MercedesTech's Avatar
MercedesTech MercedesTech is offline
MercedesTech is on a distinguished road
Cool. Can't thank ya enough Bill. Like I said, friday i should have time to tinker with it some. I will post back what I find.
And it seems fine at idle, while standing still. Its while in 4th gear that things start to seem really "off". Cruising at 52 MPH I found the rpms "hunt" some. They will shoot way up, then calm down, and bounce around a little. The converter will start locking and unlocking at slightly higher speeds. Also, converter will NOT stay locked. No matter what speed (took her up to 80 on the way home the other day to be sure) , if I remove my foot from the gas, the converter automatically unlocks.
If I turn OD off, truck drives almost completely fine. The issues are not any where near as pronounced.
"In the beginning of a change, the patriot is a brave and scarce man, hated and scorned.
When the cause succeeds, however, the timid join him...for then it cost nothing to be a patriot."
_ Mark Twain
Old Thu, March 19th, 2009, 08:53 AM
04FX4 04FX4 is offline
Mine has done this a few times as well. The difference is mine does it at low speeds, and in second gear. I notice mine when going through school zones. I have talked to Bill , but my problem is that I can not make it happen when I want, so it is hard for Bill to fix the problem. My RPMs jump about 200-400 and the TQ is not locked and it does not seem to be jumping in and out of gears.
Old Thu, March 19th, 2009, 10:10 AM
Converter unlocking during decel (ie. foot off the pedal) or when quicly accelerating (pressing down quickly on the throttle) is normal. However if the converter keeps locking and unlocking while at a steady cruise, there is a problem.
Let me know if this is what's happening.
Old Thu, March 19th, 2009, 10:42 AM
Interestingly, at least to me, Bill, is how the converter tends to stay locked with the cruise control on when going downhill. At least it did on our trip to and from California. It's almost as though it's trying to maintain the speed in a coast situation (up to a point of course) instead of just letting the vehicle speed up.
Also, reducing the shift points and torque converter lockup points both for upshifts and downshifts does seem to have helped get rid of the "eagerness" to unlock under mild load that I complained about before.
I know this post is a bit of a hijack, but thought it might add something to the knowledge base.
Old Thu, March 19th, 2009, 10:58 AM
Oddly, I've never really paid attention as to whether the converter unlocked on decel when in cruise. Since it uses an inferred throttle value, I'd assume it handled shifting in a relatively similar fashion. I do know that the throttle feed rates are much less aggressive than using your foot which may account for less frequent unlocks.
I'll have to throw something in the Expy and go for a ride this evening so I can take a closer look.
Thanks for pointing that out. Might be quite helpful!
Old Thu, March 19th, 2009, 03:16 PM
On cruise, the converter stays locked !
Hmm.... Because no matter what speed, it unlocks immediately. Doesn't feel right, but maybe just me looking for something wrong.
Anyways, yes, the converter will lock and unlock under steady acceleration. The RPMS also bounce around. when it first goes into 4th. I will feel the surge. While under steady pedal, I will feel the RPMs go up, and the truck pull (talking only a second) then drop right back down and feel slugish, then shoot back up and pull, etc. Maybe I should hook up a video camera on my guages so you can see whats happening. Sure is hard driving, and trying to stare at 8+ guages !
Jack&Janet: don't worry about hijack at all. The more the better ! Really.
_ Mark Twain
Old Thu, March 19th, 2009, 03:45 PM
kokopellimotorsports's Avatar
addicted
Subscribed.
Ty
2001 Dodge Cummins
Tuning is addicting. Lol.
Old Mon, March 23rd, 2009, 12:37 PM
OK, this thing is sporadic at best. Trying to be able to give you details is hard. 3rd gear, everything is fine. 3rd gear, converter locked, rpms bounce around slightly, nothing bad. If its at 1800 rpm in 3rd, when it shifts to 4th it shoots up to 2400-2500 rpm. Then calms down. While in fourth, it will bounce between 1400 rpms, and 2300 RPMs pretty consistantly. During my drive on sunday, it jumped up to over 3k, then back down around 1900. When it jumps up, you can feel the engine pull, and you go faster. So, its not "dry revving" but fully engaged and still revving up.
I dropped timing -2, also tried -1 neither seemed to help at all.
Shudder is still there.
_ Mark Twain
Old Mon, March 23rd, 2009, 01:36 PM
Don't want to have to mention this, but have you tried it with the STOCK program?
Just trying to eliminate weather its the tune or the tq converter.
