Old Fri, September 28th, 2012, 06:22 PM
nicmartim nicmartim is offline
nicmartim is on a distinguished road
So, my transmission is fine? No worries about the coast clutch as Cody mentioned in post #2? I did recently replace my ICP and pigtail (old one was oily in the connector). How would a new OEM part make this start or would it? Wonder if I should take the IPR apart and clean it as the PCM is getting a strong/correct (presumably) signal from the new ICP.
I am guessing this is a non-issue going forward as it concerns to drivability. Thanks guys!
Old Fri, September 28th, 2012, 10:57 PM
Probably since I read it as a new issue where wherein the RPM had just begun dropping when the torque converter clutch was released......as it should in OD. I had mistaken your first post to mean that it was a new issue that appeared regarding engine braking (which would occur in 3rd gear with the TCS or OD "OFF" light on).
My bad.
