Old Wed, October 24th, 2012, 08:18 AM
God & Guns
Yea, what he said. IIRC, I have a hard time hitting 1000* in stock. As for a rough start/Idle, does it get better as the truck becomes warmer? Is the truck plugged up? Reason I ask, it could be from cold thick oil. Many diesel owners switch to lighter and/or synthetic oil for this reason. Before you get to that hp, you will need to beef up the transmission....now or later. Make sure you EBPV is open all the way. It being slightly closed will cause higher EGT's.
