Go Back   Power Hungry Performance Forum > Power Hungry Performance Product Information > Orion Reflash System for Navistar
Power Hungry Performance is the first in the industry to provide custom tuning for the 1998 to 2007 Navistar Medium Duty platform!
If you have any questions or would like more information on Orion, please post here.
Old Thu, January 14th, 2021, 03:47 PM
pwerwagn pwerwagn is offline
pwerwagn is on a distinguished road
This was an awesome video! I just watched it, the initial acceleration is the same, if not better, than my VT365 supernova. Getting on the freeway in mine is downright dangerous on short ramps, sometimes Im only going 25mph when I finally am on the freeway. Then WOT with the "100hp" tsmp8 tuner turned all the way up, It takes a solid mile or more to get to 65.
I will second what Joe said about beating the bushes finding someone to tune these things. I have spent about 2 years talking to different people. The only reason I came across PHP was because I was considering sending my FICM to Ed to get it upgraded, and started researching the atlas tune.
Glad I found this forum!
--Jeff
Old Thu, January 14th, 2021, 08:17 PM
--Jeff
We're glad to have you here, Jeff.
As for the tuning, I'll tell ya... We've been trying to get this working for almost 15 years. We've finally been able to break down the flash routines which was the only thing really holding us up. Now that we have that down, we're really pushing forward with the Navistar stuff.
We're super excited and we know there are tons of folks out there just waiting to get their hands on this. Not much longer now.
Old Fri, February 12th, 2021, 11:37 PM
We have an 02 7400 plow truck at work with a 466. When it's full of sand (and other crappy chemicals) it won't get out of its own way. Nobody likes driving it because it's a TURD. I love it though because it doesn't make enough power to hurt itself and it's ALMOST government union employee equipment operator-proof.
Old Sat, February 13th, 2021, 10:46 AM
You could still bump it up a tad, though.
Old Sat, February 13th, 2021, 05:17 PM
I'm not sure how much the Allison in it can take above and beyond the rated power as they're mechanically calibrated for a specific power output.
It's not really worth adding power to and I did 10K-mod it years ago....still a turd.
Old Mon, February 15th, 2021, 11:15 AM
Torque capacity depends on the model of trans.
AT 545 - Good for up to 445 Ft. Lbs.
MT 643 - Good for up to 700 Ft. Lbs.
1000 Series - Good for up to 650 Ft. Lbs.
2000 Series - Good for up to 650 Ft. Lbs.
3000 Series - Good for up to 1250 Ft. Lbs. (in certain gears)
Most of the lighter duty applications use the MT 643 or the 1000/2000 series which clearly limits allowable torque output. However, since most of these engines have low HP output at the rated RPMs, the actual torque outputs are pretty low, too. For example, a T444e with a rated HP of 175 @ 2300 RPM produces about 400 Ft. Lbs. of torque. Bumping it up to 250 @2700 RPM moves the torque curve up to 480 Ft. Lbs. which, while being a bit high for an AT 545, would be well suited for an MT 643 or later model trans.
Of course, if you're running a manual then you shouldn't have any problems at all. The Eaton trans commonly found in them (the 5+1 and 6+1 O/D models) are rated north of 700 Ft. Lbs.
All this to say that unless the truck has an AT 545 in it, you should be able to safely bump the power up around 60-70 HP without any significant drawbacks or reliability issues.
Tags
diamond, dt466, hungry, logic, navistar, orion, power, reflash, skoolie, system, t444e
